Ana içeriğe geç
Dell Inspiron 13 7378 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: adım 1, 1 resimden 1.
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: adım 2, 2 resimden 1. Dell Inspiron 13 7378 Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: adım 3, 3 resimden 1. Dell Inspiron 13 7378 Wi-Fi Card Replacement: adım 3, 3 resimden 2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: adım 3, 3 resimden 3.
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 2 resimden 1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 2 resimden 2.
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samantha Gonzalez
298 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 üyesi
GCC-SAKNEE-S22S1G3
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 284
