Ana içeriğe geç
Dell Inspiron 13 N3010 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13 N3010 Hard Drive Replacement, Remove the Screw: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 13 N3010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: adım 2, 1 resimden 1.
    • Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
  3. Dell Inspiron 13 N3010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 13 N3010 Hard Drive Replacement, Remove the Four Screws: adım 4, 1 resimden 1.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13 N3010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: adım 5, 1 resimden 1.
    • Lift the hard-drive bracket away from the hard drive.
  6. Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive: adım 6, 2 resimden 1. Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive: adım 6, 2 resimden 2.
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 13 N3010 Hard Drive Replacement, Replace the Screws: adım 7, 1 resimden 1.
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive Assembly: adım 8, 1 resimden 1.
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron 13 N3010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: adım 9, 1 resimden 1.
    • Slide and connect the hard-drive assembly to the system board connector.
  10. Dell Inspiron 13 N3010 Hard Drive Replacement, Replace the Screw: adım 10, 1 resimden 1.
    • Replace the screw that secures the hard-drive assembly to the system board.
    • Turn over the system board assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 765
