Ana içeriğe geç
Dell Inspiron 13-5368 Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-5368 Fan Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 13-5368 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Fan Replacement: adım 2, 2 resimden 1. Dell Inspiron 13-5368 Fan Replacement: adım 2, 2 resimden 2.
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Fan Replacement: adım 3, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Fan Replacement: adım 4, 1 resimden 1.
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Fan Replacement: adım 5, 2 resimden 1. Dell Inspiron 13-5368 Fan Replacement: adım 5, 2 resimden 2.
    • Remove the battery.
  6. Dell Inspiron 13-5368 Fan Replacement, Fan: adım 6, 1 resimden 1.
    • Remove the 2mm X 3mm screws that are securing the fan.
  7. Dell Inspiron 13-5368 Fan Replacement: adım 7, 2 resimden 1. Dell Inspiron 13-5368 Fan Replacement: adım 7, 2 resimden 2.
    • Unplug the fan from the motherboard, then remove the fan.
Sonuç
Matt Sugrim
1.042 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G6
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,450
