Ana içeriğe geç
Dell Inspiron 13-5368 Touchpad Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-5368 Touchpad Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 13-5368 Touchpad Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Touchpad Replacement: adım 2, 2 resimden 1. Dell Inspiron 13-5368 Touchpad Replacement: adım 2, 2 resimden 2.
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Touchpad Replacement: adım 3, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Touchpad Replacement: adım 4, 1 resimden 1.
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Touchpad Replacement: adım 5, 2 resimden 1. Dell Inspiron 13-5368 Touchpad Replacement: adım 5, 2 resimden 2.
    • Remove the battery.
  6. Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: adım 6, 2 resimden 1. Dell Inspiron 13-5368 Touchpad Replacement, Touchpad: adım 6, 2 resimden 2.
    • Undo the clasps that hold the ribbon cables in place. Then, remove the ribbon cables.
  7. Dell Inspiron 13-5368 Touchpad Replacement: adım 7, 1 resimden 1.
    • Remove the 1.5mm Phillips #0 screws that hold the touchpad to the laptop case.
  8. Dell Inspiron 13-5368 Touchpad Replacement: adım 8, 2 resimden 1. Dell Inspiron 13-5368 Touchpad Replacement: adım 8, 2 resimden 2.
    • Push up on the touchpad to release it from the housing. Then you can remove the touchpad.
Sonuç
Matt Sugrim
1.042 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G6
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 3,346
