Ana içeriğe geç
Dell Inspiron 13-5368 Wifi Adapter Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-5368 Wifi Adapter Replacement, Wifi Adapter: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the 9.6 mm screws securing the back plate of the laptop.
  2. Dell Inspiron 13-5368 Wifi Adapter Replacement: adım 2, 1 resimden 1.
    • Use a prying tool to remove the back plate.
  3. Dell Inspiron 13-5368 Wifi Adapter Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
  4. Dell Inspiron 13-5368 Wifi Adapter Replacement: adım 4, 1 resimden 1.
    • Disconnect the cable connecting the battery to the motherboard, and then remove the battery
  5. Dell Inspiron 13-5368 Wifi Adapter Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the 3mm screw and the metal bracket that holds the network adapter card in place.
  6. Dell Inspiron 13-5368 Wifi Adapter Replacement: adım 6, 2 resimden 1. Dell Inspiron 13-5368 Wifi Adapter Replacement: adım 6, 2 resimden 2.
    • Pull out the network card.
    • To completely remove the network card, disconnect the two cords (white and black) from the adapter card. White on 1 and Black on 2.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Raj Dhavalikar
136 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Wilson Fall 2018 IUPUI, Team S4-G4, Wilson Fall 2018 üyesi
IUPUI-WILSON-F18S4G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 1,513
