Ana içeriğe geç
Dell Inspiron 13-7347 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7347 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 13-7347 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 13-7347 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the device over, so that the back is facing up.
    • Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Hard Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron 13-7347 Hard Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron 13-7347 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the three 4 mm JIS #00 screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Hard Drive Replacement: adım 3, 3 resimden 1. Dell Inspiron 13-7347 Hard Drive Replacement: adım 3, 3 resimden 2. Dell Inspiron 13-7347 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Unplug the flat connector that is connected to the battery.
  4. Dell Inspiron 13-7347 Hard Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 13-7347 Hard Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 13-7347 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 1. Dell Inspiron 13-7347 Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
    • Lift the hard drive up and out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 729
