Giriş
This guide will assist you to replace a new touchpad to of your Dell Inspiron 13-7347. Make sure the touchpad that you are replacing is specifically for Dell Inspiron 13-7347. It's very important to find the correct model of touchpad for your Dell Inspiron 13-7347 in order to prevent any troubles. Be sure to use the tools we suggested, and be gentle when you are using the screwdriver. Its very easy to lead to stripped screws if you didn't use the screwdriver correctly or not gentle enough.
Make sure to follow the instructions step by step carefully.
Neye ihtiyacın var
Flip the device over, so that the back is facing up.
Remove the ten, 7 mm, Phillips #1 screws on the back of your Dell Inspiron 13-7347.
Use the suction cup to lift off the back case.
