Neye ihtiyacın var
Remove the ten 7.5mm screws that secure the back panel with the Phillips #0 head
Use the plastic opening tool to remove the back panel. Start at the back corner and work across. The front edge of the laptop panel hinges and pivots upward after the back edge and the side edges are separated from the casing.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
This is perfect, but I’m curious how others may have handled an issue where the screw hole for my 7359’s power jack disintegrated. Anyone have any idea on how to anchor a power jack without that screw hole? I tried Sugru to mold around it, but that didn’t work. Any other ideas would be welcome.
