Giriş
The Memory Module (RAM) is one of the two memory storage places in your laptop. Some of your laptop's speed is dependent on the Memory Module so an upgrade may boost your laptop's overall performance if your current one if full.
Neye ihtiyacın var
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
Locate your memory module (RAM).
Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
4 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Did anyone ever get an answer if it can take 16 GB of RAM?
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
