Ana içeriğe geç
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: adım 1, 3 resimden 3.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: adım 2, 2 resimden 1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: adım 3, 1 resimden 1.
    • Gently remove the battery from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): adım 4, 3 resimden 1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): adım 4, 3 resimden 2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): adım 4, 3 resimden 3.
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: adım 5, 1 resimden 1.
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Chase Sparkman
512 İtibar
2 adet Kılavuz yazıldı
Ekip
4Kılavuz Yorumları
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - Yanıt Paylaş
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - Yanıt Paylaş
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - Yanıt Paylaş
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 3,661
