Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
If you notice your laptop is overheating, then this guide may be able to help. This guide will show you how to replace the fan in a few steps.
  1. WARNING :  Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer . After working inside your  computer, follow the instructions in After working inside your computer.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer . After working inside your computer, follow the instructions in After working inside your computer.
    • Close the display and turn the computer over
  2. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
    • Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
  4. Before opening device, ensure that all data is backed up on a hard drive to prevent data loss. Loosen and then unplug the hard drive cable.
    • Before opening device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Remove 2 M2 3mm screws, using the Phillips 1 screwdriver. Remove the battery.
    • Remove 2 M2 3mm screws, using the Phillips 1 screwdriver.
    • Remove the battery.
  6. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM. Pry open the clips and remove the RAM.
    • Pry open the clips and remove the RAM.
  7. Unplug the daughter board cable in two places marked in red, then remove it. Unplug the fan cable marked in orange. Unplug the fan cable marked in orange.
    • Unplug the daughter board cable in two places marked in red, then remove it.
    • Unplug the fan cable marked in orange.
  8. Remove 1 MR 3mm screw, using the Phillips 1 screwdriver, on the cooling fan. Remove 1 M2 2mm wafer screw, using the Phillips 1 screwdriver, on the cooling fan. Remove the cooling fan.
    • Remove 1 MR 3mm screw, using the Phillips 1 screwdriver, on the cooling fan.
    • Remove 1 M2 2mm wafer screw, using the Phillips 1 screwdriver, on the cooling fan.
    • Remove the cooling fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 213
