Ana içeriğe geç
Dell Inspiron 13-7353 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7353 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the battery up and out of the computer.
  4. Dell Inspiron 13-7353 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Unplug the hard drive cable from the motherboard.
  5. Dell Inspiron 13-7353 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove two 3mm screws from the hard drive frame.
  6. Dell Inspiron 13-7353 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Lift the hard drive up and out of the computer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 799
