Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Close the computer display and turn the computer over so that the base of the computer is facing up.
Remove the ten screws that secure the base cover to the base of the computer.
Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
Remove the battery.
Pry open the two clips.
Gently lift the RAM stick and pull it out of the motherboard.
Unplug the daughterboard cable in two places, then remove the daughterboard.
Unplug the fan cable.
Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
Remove the cooling fan from the laptop.
Remove three 2mm screws from the heat sink using a Phillips #0 screwdriver.
Remove the heat sink.
Remove 2 M2 3mm bracket screws, using the Phillips 1 screwdriver, on the LCD cable bracket.
Remove the bracket on the LCD cable.
Remove the plug of the LCD cable.
Remove the plug of the touchscreen cable.
Remove the plug of the DC Jack cable.
Remove the plug of the speaker cable.
Loosen the top of the keyboard tape.
Loosen the latches of the keyboard cable with a screwdriver.
Remove the plug of the keyboard cable.
Remove the plug of the touchpad cable.
Remove the plug of the keyboard backlight cable.
Remove one M2 2mm wafer screw, using the Phillips 1 screwdriver, from the motherboard.
Remove the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
