Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
Detach and remove the Bottom Base Cover using an opening tool to pry it off.
Unplug and gently pull the hard drive cable to loosen it.
Remove the 2 - M2 x 3mm screws.
Remove the Battery.
Remove the 2 - M2 x 3mm hard drive screws.
Remove the Hard Drive.
Unplug the fan cable.
Unplug and remove the daughter board cable.
Unplug the antenna cables.
Unplug the power button cable.
Remove the 1 - M2 x 3mm screw.
Remove the USB / SD Card Circuit Board.
Remove the 1 - M2 x 3mm and 1 - M2 x 2mm Wafer screw.
Remove the Cooling Fan.
Remove the 2 - M2 x 3mm bracket screws.
Remove the LCD cable bracket.
Open the screen.
Loosen the LCD cable and peel it off of the base (highlighted with arrow).
Remove the 3 - M2.5 x 8mm hinge screws.
Unplug the cable.
Remove the DC Jack.
Loosen the keyboard cable tape.
Loosen the keyboard cable latches.
Unplug the keyboard cable.
Unplug the keyboard backlight cable.
Unplug the touchpad cable.
Remove the 1 - M2 x 2mm Wafer screw.
Remove the Motherboard.
The piece remaining is the Palmrest Keyboard.
Unscrew the 4 - 2x2mm wafer screws.
Peel back any tape holding the back plate on.
Lift and remove back plate.
Peel back under-button tape.
Remove touchpad.
You have now stripped the keyboard! It is ready to be replaced.
5 farklı kişi bu kılavuzu tamamladı.
