Ana içeriğe geç
Dell Inspiron 13-7359 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: adım 2, 1 resimden 1.
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: adım 3, 3 resimden 1. Dell Inspiron 13-7359 Battery Replacement: adım 3, 3 resimden 2. Dell Inspiron 13-7359 Battery Replacement: adım 3, 3 resimden 3.
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: adım 4, 3 resimden 1. Dell Inspiron 13-7359 Battery Replacement: adım 4, 3 resimden 2. Dell Inspiron 13-7359 Battery Replacement: adım 4, 3 resimden 3.
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Valentin Medina
697 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G6
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,592
