Ana içeriğe geç
Dell Inspiron 13-7359 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7359 Hard Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  4. Dell Inspiron 13-7359 Hard Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 13-7359 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Valentin Medina
697 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 1,977
