Giriş
This guide to remove your Dell Inspiron 13-7359 screen. You will need a phillips #0 screwdriver and a small plastic spudger. This guide will require more time and is more difficult than the other replacement guides.
Neye ihtiyacın var
First flip over the laptop to expose the back panel
Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hi, I was wondering if there's any possibility of cross compatibility between i7378 and i7359 from dell? My computer is the i7359 but I haven't been able to find a reasonably priced replacement display. Thank you very much! Also, I found this alternate guide suggesting that the screen can be replaced slightly more easily than the manual and this guide suggests, is this process feasible? https://www.insidemylaptop.com/replacing...
