Ana içeriğe geç
Dell Inspiron 13-7359 Speaker Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: adım 2, 1 resimden 1.
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: adım 3, 3 resimden 1. Dell Inspiron 13-7359 Speaker Replacement: adım 3, 3 resimden 2. Dell Inspiron 13-7359 Speaker Replacement: adım 3, 3 resimden 3.
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: adım 4, 3 resimden 1. Dell Inspiron 13-7359 Speaker Replacement: adım 4, 3 resimden 2. Dell Inspiron 13-7359 Speaker Replacement: adım 4, 3 resimden 3.
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: adım 5, 2 resimden 1. Dell Inspiron 13-7359 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: adım 6, 2 resimden 1. Dell Inspiron 13-7359 Speaker Replacement: adım 6, 2 resimden 2.
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: adım 7, 2 resimden 1. Dell Inspiron 13-7359 Speaker Replacement: adım 7, 2 resimden 2.
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katie Ragsdale
192 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 357
