Ana içeriğe geç
Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Battery: adım 1, 1 resimden 1.
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 2, 1 resimden 1.
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 3, 3 resimden 1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 3, 3 resimden 2. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 3, 3 resimden 3.
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 4, 3 resimden 1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 4, 3 resimden 2. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 4, 3 resimden 3.
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  6. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 6, 2 resimden 1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 6, 2 resimden 2.
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
  7. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, WLAN Adaptor: adım 7, 1 resimden 1.
    • Unhook both of the wires attached to the WLAN adaptor.
  8. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 8, 1 resimden 1.
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  9. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 9, 1 resimden 1.
    • Gently remove the WLAN adaptor.
  10. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, USB/SD Card Reader IO Circuit Board: adım 10, 1 resimden 1.
    • Using the plastic opening tool, unhook the black cable as shown.
  11. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 11, 1 resimden 1.
    • Gently pull to unplug the speaker cable.
  12. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 12, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the 3.9mm Phillips screw as shown.
  13. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: adım 13, 1 resimden 1.
    • Gently raise the USB/SD Card Reader IO Circuit Board and pull the part free from the device.
Sonuç
Bo Yi Lim
205 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G4, Harley Spring 2019 IUPUI, Team S3-G4, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S3G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 347
