Ana içeriğe geç
Dell Inspiron 13-7359 WLAN Adaptor Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7359 WLAN Adaptor Replacement, Battery: adım 1, 1 resimden 1.
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 2, 1 resimden 1.
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 3, 3 resimden 1. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 3, 3 resimden 2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 3, 3 resimden 3.
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 4, 3 resimden 1. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 4, 3 resimden 2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 4, 3 resimden 3.
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 WLAN Adaptor Replacement, WLAN Adaptor: adım 5, 1 resimden 1.
    • Unhook both of the wires attached to the WLAN adaptor.
  6. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 6, 1 resimden 1.
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  7. Dell Inspiron 13-7359 WLAN Adaptor Replacement: adım 7, 1 resimden 1.
    • Gently remove the WLAN adaptor.
Sonuç
Bo Yi Lim
205 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G4, Harley Spring 2019 IUPUI, Team S3-G4, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S3G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 165
