Ana içeriğe geç
Dell Inspiron 13-7370 Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: adım 1, 3 resimden 1. Dell Inspiron 13-7370 Fan Replacement, Fan: adım 1, 3 resimden 2. Dell Inspiron 13-7370 Fan Replacement, Fan: adım 1, 3 resimden 3.
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: adım 2, 2 resimden 1. Dell Inspiron 13-7370 Fan Replacement: adım 2, 2 resimden 2.
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: adım 3, 2 resimden 1. Dell Inspiron 13-7370 Fan Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: adım 4, 2 resimden 1. Dell Inspiron 13-7370 Fan Replacement: adım 4, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: adım 5, 3 resimden 1. Dell Inspiron 13-7370 Fan Replacement: adım 5, 3 resimden 2. Dell Inspiron 13-7370 Fan Replacement: adım 5, 3 resimden 3.
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: adım 6, 1 resimden 1.
    • Remove the fan from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zayed Azam
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 753
