Ana içeriğe geç
Dell Inspiron 13-7373 Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: adım 1, 3 resimden 1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: adım 1, 3 resimden 2. Dell Inspiron 13-7373 Fan Replacement, Back Cover: adım 1, 3 resimden 3.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: adım 2, 1 resimden 1.
    • Remove the two screws holding the cover for the fan.
  3. Dell Inspiron 13-7373 Fan Replacement: adım 3, 1 resimden 1.
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
Sonuç
To reassemble your device with the new fan, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Kameron Jusseaume
483 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G4
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - Yanıt
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 1,220
