Ana içeriğe geç
Dell Inspiron 13-7373 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: adım 2, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: adım 3, 2 resimden 1. Dell Inspiron 13-7373 Motherboard Replacement: adım 3, 2 resimden 2.
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 13-7373 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: adım 5, 1 resimden 1.
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: adım 6, 1 resimden 1.
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: adım 7, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: adım 8, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: adım 11, 3 resimden 1. Dell Inspiron 13-7373 Motherboard Replacement: adım 11, 3 resimden 2. Dell Inspiron 13-7373 Motherboard Replacement: adım 11, 3 resimden 3.
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: adım 12, 1 resimden 1.
    • Gently lift up on the motherboard to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Egan
437 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,215
