Ana içeriğe geç
Dell Inspiron 1318 Memory Module Replacement
    1. Dell Inspiron 1318 Memory Module Replacement, Popping up the Memory Module: adım 1, 1 resimden 1.
      • Follow the procedures in Before You Begin.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 1318 Memory Module Replacement, Remove the Module: adım 2, 1 resimden 1.
      • Remove the module from the connector.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 1318 Memory Module Replacement, Align the Notch: adım 3, 1 resimden 1.
      • Align the notch in the module edge connector with the tab in the connector slot.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 1318 Memory Module Replacement, Sliding the Module: adım 4, 1 resimden 1.
      • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Terrence15
80.125 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
11.760 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 290
