Ana içeriğe geç
Dell Inspiron 13z 5323 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 13z 5323 Battery Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 13z 5323 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: adım 2, 3 resimden 1. Dell Inspiron 13z 5323 Battery Replacement: adım 2, 3 resimden 2. Dell Inspiron 13z 5323 Battery Replacement: adım 2, 3 resimden 3.
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: adım 3, 3 resimden 1. Dell Inspiron 13z 5323 Battery Replacement: adım 3, 3 resimden 2. Dell Inspiron 13z 5323 Battery Replacement: adım 3, 3 resimden 3.
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: adım 4, 3 resimden 1. Dell Inspiron 13z 5323 Battery Replacement: adım 4, 3 resimden 2. Dell Inspiron 13z 5323 Battery Replacement: adım 4, 3 resimden 3.
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
Sonuç
Chase Hussey
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 UMass Dartmouth, Team S5-G6, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 876
