Ana içeriğe geç
Dell Inspiron 14 5100 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: adım 1, 3 resimden 1. Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: adım 1, 3 resimden 2. Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: adım 1, 3 resimden 3.
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Hard Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 14 5100 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Hard Drive Replacement, Battery: adım 3, 2 resimden 1. Dell Inspiron 14 5100 Hard Drive Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Hard Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 14 5100 Hard Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 14 5100 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
  5. Dell Inspiron 14 5100 Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Unplug the connectors from the hard drive and slide it out of its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 74
Her zaman: 2,217
