Ana içeriğe geç
Dell Inspiron 14 5100 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: adım 1, 3 resimden 1. Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: adım 1, 3 resimden 2. Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: adım 1, 3 resimden 3.
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 14 5100 RAM Replacement: adım 2, 2 resimden 2.
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 RAM Replacement: adım 4, 2 resimden 1. Dell Inspiron 14 5100 RAM Replacement: adım 4, 2 resimden 2.
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 RAM Replacement: adım 5, 1 resimden 1.
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 71
Her zaman: 1,195
