Ana içeriğe geç
Dell Inspiron 14 5443 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14 5443 Hard Drive Replacement, Removing screws: adım 1, 1 resimden 1.
    • Remove the screws that secure the hard-drive assembly to the base frame.
  2. Dell Inspiron 14 5443 Hard Drive Replacement, Gently Lift Hard-Drive: adım 2, 1 resimden 1.
    • Gently lift the hard-drive assembly out of the base frame and disconnect the hard-drive cable from the hard drive.
  3. Dell Inspiron 14 5443 Hard Drive Replacement, Removing Screws From Bracket: adım 3, 1 resimden 1.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 5443 Hard Drive Replacement, Lifting Bracket: adım 4, 1 resimden 1.
    • Lift the hard-drive bracket off the hard drive
  5. Dell Inspiron 14 5443 Hard Drive Replacement, Placing Bracket: adım 5, 1 resimden 1.
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 5443 Hard Drive Replacement, Aligning the Screws: adım 6, 1 resimden 1.
    • Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
  7. Dell Inspiron 14 5443 Hard Drive Replacement, Replace the Screws: adım 7, 1 resimden 1.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14 5443 Hard Drive Replacement, Connecting Hard-Drive To Cable: adım 8, 1 resimden 1.
    • Connect the hard-drive cable to the hard drive.
  9. Dell Inspiron 14 5443 Hard Drive Replacement, Placing the Hard-Drive: adım 9, 1 resimden 1.
    • Place the hard-drive assembly in the base frame and align the screw holes on the hard-drive assembly with the screw holes on the base frame.
  10. Dell Inspiron 14 5443 Hard Drive Replacement, Securing the Screws: adım 10, 1 resimden 1.
    • Replace the screws that secure the hard-drive assembly to the base frame.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
darrius
5.213 İtibar
30 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 230
