Giriş
How To remove and replace the Hard Drive.
Neye ihtiyacın var
Remove the screws that secure the hard-drive assembly to the base frame.
Gently lift the hard-drive assembly out of the base frame and disconnect the hard-drive cable from the hard drive.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Place the hard-drive assembly in the base frame and align the screw holes on the hard-drive assembly with the screw holes on the base frame.
Replace the screws that secure the hard-drive assembly to the base frame.
Bir başkası bu kılavuzu tamamladı.
