Giriş
In this guide, we will show you how to remove and replace the Hard Drive.
Neye ihtiyacın var
Using the pull-tab, disconnect the hard-drive cable from the system board.
Remove the screws that secure the hard-drive assembly to the computer base.
Gently lift the hard-drive assembly out of the computer base.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
Replace the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
