Ana içeriğe geç
Dell Inspiron 14 Gaming 7466 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Camera Cable: adım 1, 1 resimden 1.
  2. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peeling the Camera Cable: adım 2, 1 resimden 1.
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Antenna Cables: adım 3, 1 resimden 1.
    • Remove the antenna cables from the routing guides on the computer base.
  4. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screw: adım 4, 1 resimden 1.
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  5. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Cable Bracket: adım 5, 1 resimden 1.
    • Lift the display-cable bracket off the system board.
  6. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Display Cable: adım 6, 1 resimden 1.
    • Using the pull-tab, disconnect the display cable from the system board.
  7. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peel off the Display Cable: adım 7, 1 resimden 1.
    • Peel off the display cable from the computer base.
  8. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: adım 8, 1 resimden 1.
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: adım 9, 1 resimden 1.
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Open the Display: adım 10, 1 resimden 1.
    • Turn the computer over and open the display.
  11. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: adım 11, 1 resimden 1.
  12. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Assembly: adım 12, 1 resimden 1.
    • Lift the display assembly off the computer base.
  13. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Holes: adım 13, 1 resimden 1.
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  14. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: adım 14, 1 resimden 1.
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: adım 15, 1 resimden 1.
    • Close the display and turn the computer over.
  16. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: adım 16, 1 resimden 1.
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  17. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Adhering the Cables: adım 17, 1 resimden 1.
    • Adhere the display cable and the camera cable to the computer base.
  18. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Connect the Display Cable: adım 18, 1 resimden 1.
    • Connect the display cable and camera cable to the system board.
  19. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Hole: adım 19, 1 resimden 1.
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  20. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screw: adım 20, 1 resimden 1.
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
Bitiş Çizgisi
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 129
