Giriş
In this guide, we will show you how to remove and replace the Hard Drive.
Neye ihtiyacın var
Remove the screw (M2x3) that secures the solid-state drive to the computer base.
Slide and remove the solid-state drive from the solid-state drive slot.
Align the notch on the solid-state drive with the tab on the solid-state drive slot, and slide the solid-state drive into the solid-state drive slot.
Press the other end of the solid-state drive to align the screw hole on the solid-state drive with the screw hole on the computer base.
Replace the screw (M2x3) that secures the solid-state drive to the computer base.
