Ana içeriğe geç
Dell Inspiron 14 M4040 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14 M4040 Display Assembly Replacement, Disconnecting the Display Cable: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the display cable from the connector on the system board.
  2. Dell Inspiron 14 M4040 Display Assembly Replacement, Disconnect the Cables: adım 2, 1 resimden 1.
    • Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
  3. Dell Inspiron 14 M4040 Display Assembly Replacement, Remove the Cables: adım 3, 1 resimden 1.
    • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
  4. Dell Inspiron 14 M4040 Display Assembly Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the two screws that secure the display assembly to the computer base.
  5. Dell Inspiron 14 M4040 Display Assembly Replacement, Removing the Display Assembly: adım 5, 1 resimden 1.
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron 14 M4040 Display Assembly Replacement, Placing the Display Assembly: adım 6, 1 resimden 1.
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 14 M4040 Display Assembly Replacement, Routing the Cable: adım 7, 1 resimden 1.
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron 14 M4040 Display Assembly Replacement, Connect the Display Cable: adım 8, 1 resimden 1.
    • Connect the display cable to the connector on the system board.
Bitiş Çizgisi
Terrence15
79.161 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 86
