Ana içeriğe geç
Dell Inspiron 14 M4040 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14 M4040 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Dell Inspiron 14 M4040 Hard Drive Replacement, Lifting the Hard-Drive Assembly: adım 2, 1 resimden 1.
    • Lift the hard-drive assembly out of the computer base.
  3. Dell Inspiron 14 M4040 Hard Drive Replacement, Remove the Screws: adım 3, 1 resimden 1.
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 M4040 Hard Drive Replacement, Placing the Hard Drive: adım 4, 2 resimden 1. Dell Inspiron 14 M4040 Hard Drive Replacement, Placing the Hard Drive: adım 4, 2 resimden 2.
    • Place the hard-drive bracket on the NEW hard drive.
  5. Dell Inspiron 14 M4040 Hard Drive Replacement, Replace the Two Screws: adım 5, 1 resimden 1.
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 14 M4040 Hard Drive Replacement, Placing the Hard Drive Assembly: adım 6, 1 resimden 1.
    • Place the hard-drive assembly on the computer base.
  7. Dell Inspiron 14 M4040 Hard Drive Replacement, Pushing the Hard-Drive Assembly: adım 7, 1 resimden 1.
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
Bitiş Çizgisi
Terrence15
79.161 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 181
