Ana içeriğe geç
Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): adım 2, 1 resimden 1.
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: adım 3, 1 resimden 1.
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: adım 4, 1 resimden 1.
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: adım 5, 1 resimden 1.
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alec Siegel
598 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G2, Johnson Spring 2018 Baylor, Team S2-G2, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G2
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 779
