Ana içeriğe geç
Dell Inspiron 14-5447 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 14-5447 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: adım 3, 2 resimden 1. Dell Inspiron 14-5447 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: adım 4, 2 resimden 1. Dell Inspiron 14-5447 Battery Replacement: adım 4, 2 resimden 2.
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 3,068
