Ana içeriğe geç
Dell Inspiron 14-5447 Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-5447 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Fan Replacement: adım 2, 2 resimden 1. Dell Inspiron 14-5447 Fan Replacement: adım 2, 2 resimden 2.
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Fan Replacement: adım 3, 2 resimden 1. Dell Inspiron 14-5447 Fan Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Fan Replacement: adım 4, 2 resimden 1. Dell Inspiron 14-5447 Fan Replacement: adım 4, 2 resimden 2.
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Fan Replacement, Fan: adım 5, 1 resimden 1.
    • Locate the fan system in the top right corner.
  6. Dell Inspiron 14-5447 Fan Replacement: adım 6, 2 resimden 1. Dell Inspiron 14-5447 Fan Replacement: adım 6, 2 resimden 2.
    • Look along the wide line of white cable until you find the tab insert.
    • Remove the thick white cable crossing over the fan, using the blue spudger shown, to flip the securing flap holding down the cable.
  7. Dell Inspiron 14-5447 Fan Replacement: adım 7, 2 resimden 1. Dell Inspiron 14-5447 Fan Replacement: adım 7, 2 resimden 2.
    • Move the cable over to the side to reveal the fan screws.
    • Remove the two black 5.70 mm screws from the fan.
  8. Dell Inspiron 14-5447 Fan Replacement: adım 8, 2 resimden 1. Dell Inspiron 14-5447 Fan Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the small cable attached to the fan.
  9. Dell Inspiron 14-5447 Fan Replacement: adım 9, 2 resimden 1. Dell Inspiron 14-5447 Fan Replacement: adım 9, 2 resimden 2.
    • Using the opening tool, pry the fan out.
    • Remove the fan slowly to prevent damage to any wires or cables connected to the device.
  10. Dell Inspiron 14-5447 Fan Replacement: adım 10, 1 resimden 1.
    • Now that the fan is removed, be sure to clean the area under the fan to prevent overheating.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 840
