Ana içeriğe geç
Dell Inspiron 14-5447 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-5447 Wi-Fi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 2, 2 resimden 1. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 3, 2 resimden 1. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Wi-Fi Card Replacement, Wi-Fi Card: adım 5, 2 resimden 1. Dell Inspiron 14-5447 Wi-Fi Card Replacement, Wi-Fi Card: adım 5, 2 resimden 2.
    • Locate the Wifi card on the top left of the laptop.
    • Use the tweezers to release the black and white cables.
  6. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Remove one silver 2.9mm Phillips #1 screw which secures the WiFi card.
  7. Dell Inspiron 14-5447 Wi-Fi Card Replacement: adım 7, 1 resimden 1.
    • The Wi-Fi card should slide out of the black socket.
    • Use tweezers to push the white part of the Wi-Fi card up towards the top of the device to remove.
    • Remove the card with the tweezers.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,227
