Ana içeriğe geç
Dell Inspiron 14-7437 Base Cover Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-7437 Base Cover Replacement, Base Cover: adım 1, 2 resimden 1. Dell Inspiron 14-7437 Base Cover Replacement, Base Cover: adım 1, 2 resimden 2.
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Base Cover Replacement: adım 2, 2 resimden 1. Dell Inspiron 14-7437 Base Cover Replacement: adım 2, 2 resimden 2.
    • Pry open the back cover using a spudger and slide it along the under the cover.
Sonuç
Travis Connolly
330 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-8, Catania Spring 2016 UMass Dartmouth, Team 7-8, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G8
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,706
