Ana içeriğe geç
Dell Inspiron 14-7437 Cooling Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-7437 Cooling Fan Replacement, Base Cover: adım 1, 2 resimden 1. Dell Inspiron 14-7437 Cooling Fan Replacement, Base Cover: adım 1, 2 resimden 2.
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Cooling Fan Replacement: adım 2, 2 resimden 1. Dell Inspiron 14-7437 Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Cooling Fan Replacement, Battery: adım 3, 2 resimden 1. Dell Inspiron 14-7437 Cooling Fan Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 1. Dell Inspiron 14-7437 Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 2.
    • Remove the two 2.5 mm screws using a J000 Phillips Head Screwdriver.
  7. Dell Inspiron 14-7437 Cooling Fan Replacement: adım 7, 2 resimden 1. Dell Inspiron 14-7437 Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Pull up on the wire and remove the Cooling Fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katelyn Remy
449 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-8, Catania Spring 2016 UMass Dartmouth, Team 7-8, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G8
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 733
