Giriş
The Cooling fan is used to remove heat from the laptop so it is not hot to the touch and does not burn the motherboard.
Neye ihtiyacın var
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Bir başkası bu kılavuzu tamamladı.
