Ana içeriğe geç
Dell Inspiron 14-7437 Thermal Cooling Fan Replacement
Neye ihtiyacın var
  1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: adım 1, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: adım 1, 2 resimden 2.
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 2, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: adım 3, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Speaker: adım 6, 1 resimden 1.
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 7, 3 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 7, 3 resimden 2. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 7, 3 resimden 3.
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Coin Cell Battery: adım 8, 1 resimden 1.
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 9, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 9, 2 resimden 2.
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
  10. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: adım 10, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: adım 10, 2 resimden 2.
    • Remove the two 2.5 mm screws using a J000 Phillips Head Screwdriver.
  11. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 11, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 11, 2 resimden 2.
    • Pull up on the wire and remove the Cooling Fan.
  12. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: adım 12, 3 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: adım 12, 3 resimden 2. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: adım 12, 3 resimden 3.
    • Disconnect cables connected to the motherboard by lifting the flaps up and pulling out.
    • This is a ZIF connector and needs to have the side flaps flipped up before removal.
    • The ZIF connector has small clips that need to be pulled up before being pulled out.
  13. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 13, 3 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 13, 3 resimden 2. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 13, 3 resimden 3.
    • Remove the eight 2.5 mm screws using a J000 Phillips Head Screwdriver.
  14. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 14, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 14, 2 resimden 2.
    • Flip the motherboard.
  15. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 15, 2 resimden 1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 15, 2 resimden 2.
    • Loosen the three 2.5 mm screws using the J000 Phillips Head Screwdriver.
    • These three 2.5 mm screws cannot be removed from the Thermal Cooling assembly.
  16. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: adım 16, 1 resimden 1.
    • Remove the Thermal-Cooling Assembly from the motherboard.
Sonuç
Katelyn Remy
449 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-8, Catania Spring 2016 UMass Dartmouth, Team 7-8, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S7G8
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,079
