Ana içeriğe geç
Dell Inspiron 1420 Disassembly
Neye ihtiyacın var
    1. Dell Inspiron 1420 Disassembly, Remove Battery: adım 1, 2 resimden 1. Dell Inspiron 1420 Disassembly, Remove Battery: adım 1, 2 resimden 2.
      • Press both indicated locks on the bottom side of the laptop to release and remove the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: adım 2, 2 resimden 1. Dell Inspiron 1420 Disassembly, Unscrew Back Panel Screws: adım 2, 2 resimden 2.
      • Loosen and remove indicated screws on the back panel using a Phillips #1 screwdriver.
      • Back cover screws
      • These screws are a different length than the others and can be stored separately for reassembly.
      • Hard drive cover screws
      • RAM cover screws
      • CD drive cover screw
      • Heat sink cover screws
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 1420 Disassembly, Remove Hard Drive: adım 3, 1 resimden 1.
      • Remove the hard drive cover.
      • Pull the tab in the direction of the arrows to remove the hard drive.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 1420 Disassembly, Remove CD Drive: adım 4, 2 resimden 1. Dell Inspiron 1420 Disassembly, Remove CD Drive: adım 4, 2 resimden 2.
      • Using a screwdriver, slide out the CD drive bracket enough for it to be grabbed.
      • Remove CD drive from housing.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Inspiron 1420 Disassembly, Remove RAM: adım 5, 2 resimden 1. Dell Inspiron 1420 Disassembly, Remove RAM: adım 5, 2 resimden 2.
      • Remove RAM cover.
      • Pull the metal tabs above and below the RAM outward and remove both RAM sticks.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Inspiron 1420 Disassembly, Remove Heat Sink: adım 6, 3 resimden 1. Dell Inspiron 1420 Disassembly, Remove Heat Sink: adım 6, 3 resimden 2. Dell Inspiron 1420 Disassembly, Remove Heat Sink: adım 6, 3 resimden 3.
      • Remove the heat sink cover.
      • Using a Phillips #1 screwdriver, loosen and remove screws from heat sink.
      • Remove the heat sink.
      FixBot'a Sor
      Yorum Ekle
    7. Dell Inspiron 1420 Disassembly, Remove CPU: adım 7, 3 resimden 1. Dell Inspiron 1420 Disassembly, Remove CPU: adım 7, 3 resimden 2. Dell Inspiron 1420 Disassembly, Remove CPU: adım 7, 3 resimden 3.
      • Using a flathead screwdriver, quarter turn the screw anticlockwise to release the CPU.
      • Gently lift the CPU out of the housing.
      • The pins on the bottom of the CPU are very fragile and will not function if any are bent.
      FixBot'a Sor
      Yorum Ekle
    8. Dell Inspiron 1420 Disassembly, Remove Bracket: adım 8, 2 resimden 1. Dell Inspiron 1420 Disassembly, Remove Bracket: adım 8, 2 resimden 2.
      • Using a Phillips #1 screwdriver, unscrew and remove bracket.
      • There may be a card along with the bracket in your machine. If there is, unplug and remove this card as well.
      FixBot'a Sor
      Yorum Ekle
    9. Dell Inspiron 1420 Disassembly, Remove Back Screws: adım 9, 1 resimden 1.
      • Using a Phillips #1 screwdriver, loosen and remove the indicated screws.
      FixBot'a Sor
      Yorum Ekle
    10. Dell Inspiron 1420 Disassembly, Pry Control Panel: adım 10, 1 resimden 1.
      • Use a spudger to pry off the control panel.
      FixBot'a Sor
      Yorum Ekle
    11. Dell Inspiron 1420 Disassembly, Pry Hinge Covers: adım 11, 1 resimden 1.
      • Use a spudger to pry off the hinge covers.
      FixBot'a Sor
      Yorum Ekle
    12. Dell Inspiron 1420 Disassembly, Remove Keyboard Screws: adım 12, 1 resimden 1.
      • Using a Phillips #1 screwdriver, loosen and remove the keyboard screws.
      FixBot'a Sor
      Yorum Ekle
    13. Dell Inspiron 1420 Disassembly, Remove Keyboard: adım 13, 2 resimden 1. Dell Inspiron 1420 Disassembly, Remove Keyboard: adım 13, 2 resimden 2.
      • Gently lift keyboard to reveal blue ribbon connection.
      • Use a spudger to flip the blue ribbon lever and release the keyboard.
      FixBot'a Sor
      Yorum Ekle
    14. Dell Inspiron 1420 Disassembly, Remove Wifi-Card: adım 14, 2 resimden 1. Dell Inspiron 1420 Disassembly, Remove Wifi-Card: adım 14, 2 resimden 2.
      • Using a Phillips #1 screwdriver, remove the screw holding in the Wi-Fi card.
      • Unplug cables connected to Wi-Fi card.
      • Slide Wi-Fi card out of connection to remove.
      FixBot'a Sor
      Yorum Ekle
    15. Dell Inspiron 1420 Disassembly, Lift Control Panel: adım 15, 2 resimden 1. Dell Inspiron 1420 Disassembly, Lift Control Panel: adım 15, 2 resimden 2.
      • Using a Phillips #1 screwdriver, loosen and remove control panel screw.
      • Carefully pull up control panel. Being sure to keep the cable attached, set to the side.
      FixBot'a Sor
      Yorum Ekle
    16. Dell Inspiron 1420 Disassembly, Remove Monitor: adım 16, 2 resimden 1. Dell Inspiron 1420 Disassembly, Remove Monitor: adım 16, 2 resimden 2.
      • Pull the blue tab up to release the monitor.
      • Remove monitor.
      FixBot'a Sor
      Yorum Ekle
    17. Dell Inspiron 1420 Disassembly, Remove Screws: adım 17, 1 resimden 1.
      • Using a Phillips #1 screwdriver, remove remaining screws from cover panel.
      FixBot'a Sor
      Yorum Ekle
    18. Dell Inspiron 1420 Disassembly, Unplug Connections: adım 18, 3 resimden 1. Dell Inspiron 1420 Disassembly, Unplug Connections: adım 18, 3 resimden 2. Dell Inspiron 1420 Disassembly, Unplug Connections: adım 18, 3 resimden 3.
      • Using a spudger, disconnect control panel motherboard cable.
      • Using a spudger, flip up blue lever and disconnect touchpad cable.
      FixBot'a Sor
      Yorum Ekle
    19. Dell Inspiron 1420 Disassembly, Remove Screws and Connections: adım 19, 1 resimden 1.
      • Lift off cover panel.
      • Using a Phillips #1 screwdriver, loosen and remove screws from motherboard.
      • Disconnect the indicated cables from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    20. Dell Inspiron 1420 Disassembly, Remove SIM Board: adım 20, 1 resimden 1.
      • Using a Phillips #1 screwdriver, remove screw.
      • Disconnect indicated cable and remove SIM board.
      FixBot'a Sor
      Yorum Ekle
    21. Dell Inspiron 1420 Disassembly, Remove Memory Card Holder: adım 21, 1 resimden 1.
      • Slide memory card holder out of housing.
      FixBot'a Sor
      Yorum Ekle
    22. Dell Inspiron 1420 Disassembly, Remove Modem Card: adım 22, 1 resimden 1.
      • Flip laptop over to show backplate.
      • Loosen and remove modem card screw using a Phillips #1 screwdriver.
      • Remove modem card.
      FixBot'a Sor
      Yorum Ekle
    23. Dell Inspiron 1420 Disassembly, Release Motherboard: adım 23, 2 resimden 1. Dell Inspiron 1420 Disassembly, Release Motherboard: adım 23, 2 resimden 2.
      • Flip laptop over and gently pull motherboard away from backplate.
      • Disconnect the indicated connection to release the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Braxton Quillin
184 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 41
Her zaman: 553
