Ana içeriğe geç
Dell Inspiron 1420 Display Replacement
Neye ihtiyacın var
    1. Dell Inspiron 1420 Display Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1420 Display Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1420 Display Replacement, Battery: adım 1, 3 resimden 3.
      • Slide the two tabs to release the battery.
      • Pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: adım 2, 3 resimden 1. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: adım 2, 3 resimden 2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: adım 2, 3 resimden 3.
      • Use a spudger to pry the 6 rubber bumpers from the display.
      • Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: adım 3, 3 resimden 1. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: adım 3, 3 resimden 2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: adım 3, 3 resimden 3.
      • Gently pry the frame using a spudger.
      • Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: adım 4, 3 resimden 1. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: adım 4, 3 resimden 2. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: adım 4, 3 resimden 3.
      • Use a spudger to loosen the frame from the top.
      • Lift up the black connector to detach the gold ribbon.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: adım 5, 2 resimden 1. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: adım 5, 2 resimden 2.
      • Pull directly up on the light blue tab.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Inspiron 1420 Display Replacement, VGA cable: adım 6, 3 resimden 1. Dell Inspiron 1420 Display Replacement, VGA cable: adım 6, 3 resimden 2. Dell Inspiron 1420 Display Replacement, VGA cable: adım 6, 3 resimden 3.
      • Squeeze the two metal clips located on the VGA cable.
      • Pull while squeezing the clips in order to remove the cable.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Inspiron 1420 Display Replacement, Isolating the Display: adım 7, 3 resimden 1. Dell Inspiron 1420 Display Replacement, Isolating the Display: adım 7, 3 resimden 2. Dell Inspiron 1420 Display Replacement, Isolating the Display: adım 7, 3 resimden 3.
      • Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
      • Remove the metal brackets, one on each side, by gently pulling.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kris Karanxha
298 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Blackwell Fall 2014 USF Tampa, Team 2-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G4
4 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 57
Her zaman: 2,998
