Ana içeriğe geç
Dell Inspiron 1420 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1420 Hard Drive Replacement, Loosen the Screws: adım 1, 1 resimden 1.
    • CAUTION: Before working inside your computer, Follow the procedures in Before You Begin.
    • Turn the computer over.
    • Loosen the two captive screws securing the hard drive cover and then remove the cover.
  2. Dell Inspiron 1420 Hard Drive Replacement, Remove the Hard Drive Assembly: adım 2, 2 resimden 1. Dell Inspiron 1420 Hard Drive Replacement, Remove the Hard Drive Assembly: adım 2, 2 resimden 2.
    • Remove the hard drive assembly using the pull-tab.
  3. Dell Inspiron 1420 Hard Drive Replacement, Removing the Screws: adım 3, 1 resimden 1.
    • Remove the two screws securing the hard drive to the hard drive assembly.
  4. Dell Inspiron 1420 Hard Drive Replacement, Removing the Hard Drive: adım 4, 2 resimden 1. Dell Inspiron 1420 Hard Drive Replacement, Removing the Hard Drive: adım 4, 2 resimden 2.
    • Slide out the hard drive from the hard drive assembly.
  5. Dell Inspiron 1420 Hard Drive Replacement, Sliding the Hard Drive: adım 5, 2 resimden 1. Dell Inspiron 1420 Hard Drive Replacement, Sliding the Hard Drive: adım 5, 2 resimden 2.
    • Slide the NEW hard drive in the hard drive assembly.
    • NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
  6. Dell Inspiron 1420 Hard Drive Replacement, Tighten the Screws: adım 6, 1 resimden 1.
    • Tighten the two screws to secure the hard drive to the hard drive assembly.
  7. Dell Inspiron 1420 Hard Drive Replacement, Placing the Hard Drive Assembly: adım 7, 1 resimden 1.
    • Place the hard drive assembly in the hard drive bay by aligning the tabs on the hard drive assembly with the slots in the bay and pressing the connector end down.
  8. Dell Inspiron 1420 Hard Drive Replacement, Replace the Hard Drive Door: adım 8, 2 resimden 1. Dell Inspiron 1420 Hard Drive Replacement, Replace the Hard Drive Door: adım 8, 2 resimden 2.
    • Replace the hard drive door and tighten the screws.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,236
