Giriş
1. adıma git ↓Do you find that your computer overheats frequently? Your heat sink may be faulty, which would cause your processor to run hotter than it should. Replacing your heat sink is very simple and can be done with the help of this guide.
Neye ihtiyacın var
Aletler
Using a Phillips #00 screwdriver, remove the three 5mm screws.
Lift the panel and set it aside.
