Ana içeriğe geç
Dell Inspiron 1420 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Inspiron 1420 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 1420 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 1420 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
      • Slide the two tabs to release the battery.
      • Pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 1420 Keyboard Replacement, Open the laptop: adım 2, 1 resimden 1.
      • Open the lid as far back as possible.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 1420 Keyboard Replacement, Remove top cover plate: adım 3, 2 resimden 1. Dell Inspiron 1420 Keyboard Replacement, Remove top cover plate: adım 3, 2 resimden 2.
      • Using a spudger, pry off the top cover plate, thus exposing the screws for the keyboard.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 1420 Keyboard Replacement, Unscrew keyboard screws: adım 4, 3 resimden 1. Dell Inspiron 1420 Keyboard Replacement, Unscrew keyboard screws: adım 4, 3 resimden 2. Dell Inspiron 1420 Keyboard Replacement, Unscrew keyboard screws: adım 4, 3 resimden 3.
      • Using a Phillips #00 screwdriver, unscrew the two 3mm screws holding the keyboard down.
      • When removing the keyboard, be cautious not to damage the connecting ribbon underneath.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 1420 Keyboard Replacement, Remove keyboard: adım 5, 3 resimden 1. Dell Inspiron 1420 Keyboard Replacement, Remove keyboard: adım 5, 3 resimden 2. Dell Inspiron 1420 Keyboard Replacement, Remove keyboard: adım 5, 3 resimden 3.
      • Using a spudger, carefully lift the blue tab, releasing the ribbon connector and freeing the keyboard to be removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brandon
55 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Blackwell Fall 2014 USF Tampa, Team 2-4, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S2G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 1,962
