Ana içeriğe geç
Dell Inspiron 1425 Hard-Drive Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screw: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Sliding the Hard Drive Assembly: adım 2, 1 resimden 1.
    • Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
  3. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: adım 5, 2 resimden 1. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: adım 5, 2 resimden 2.
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive: adım 6, 1 resimden 1.
    • Place the hard drive in the hard-drive bracket.
  7. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screws: adım 7, 1 resimden 1.
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: adım 8, 1 resimden 1.
    • Place the NEW hard-drive assembly on the system board.
  9. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Slding the Hard-Drive Assembly: adım 9, 1 resimden 1.
    • Slide the hard-drive assembly to connect it to the connector on the system board.
  10. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screw: adım 10, 1 resimden 1.
    • Replace the screw that secures the hard-drive assembly to the system board.
Bitiş Çizgisi
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 133
