Ana içeriğe geç
Dell Inspiron 1440 Touch Pad Buttons Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: adım 1, 2 resimden 1. Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: adım 1, 2 resimden 2.
    • Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
    • Once it pops out, pull it off.
  2. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the screws at the top of the keyboard.
  3. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 3, 1 resimden 1.
    • Lift from the top part of the keyboard and pull out.
  4. Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: adım 4, 2 resimden 1. Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: adım 4, 2 resimden 2.
    • Remove all of the 6 mm screws on the bottom of the laptop.
    • There are some that go along the edge and some that surrounding and underneath a middle plate.
  5. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 5, 2 resimden 1. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 5, 2 resimden 2.
    • Remove the 6 mm screws that are in the silver metal plate under the keyboard.
    • Disconnect any wires that are attached to the metal plate.
  6. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 6, 2 resimden 1. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 6, 2 resimden 2.
    • Once all of the screws are out of the silver plate and the bottom of the laptop, pull silver plate, which is attached to the silver plastic on top, off of the laptop.
  7. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 7, 2 resimden 1. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 7, 2 resimden 2.
    • Flip over the silver plate, and remove the 3 mm screw attached the buttons.
    • Remove the ribbon cables that are also attached.
  8. Dell Inspiron 1440 Touch Pad Buttons Replacement: adım 8, 1 resimden 1.
    • Remove the buttons.
Sonuç
Tyler Lyons
452 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Barthe Fall 2019 UMass Dartmouth, Team S1-G3, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 340
