Ana içeriğe geç
Dell Inspiron 1464 Memory Modules Replacement
  1. Dell Inspiron 1464 Memory Modules Replacement, Popping up the Memory Module: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Dell Inspiron 1464 Memory Modules Replacement, Remove the Memory Module: adım 2, 1 resimden 1.
    • Remove the memory module from the memory module connector.
  3. Dell Inspiron 1464 Memory Modules Replacement, Align the Notch: adım 3, 1 resimden 1.
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  4. Dell Inspiron 1464 Memory Modules Replacement, Sliding the Module: adım 4, 1 resimden 1.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Bitiş Çizgisi
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 120
